Failed to add a TLV when constructing an outgoing TLV. This could happen when there is not enough room to fit all requested TLVs. Errors greater than 0 mean not enough space, all others are smaller than 0.
This message is for debug purposes only, and should only be enabled on request of Extreme Networks Technical Support.
Debug-Verbose
Adding TLV to transmit LLDPDU failed[%error%] on port %port% for %TLV%
| Name | Type |
| port | SlotPort |
| TLV | String |
| error | uInt |
